Another oil filter adapter question
Skywagon92G
I'm New Here
Long time listener, first time caller.
I recently purchased a RV4 with a io320 and a constant speed. It has the ADF remote oil filter and I’d like to get rid of that and install an oil filter adapter. I have what I believe is a Casper but I can’t seem to get a straight answer about whether it will fit with the dynafocal mount or not. Any advice?
I fly quite a bit so I’m trying to avoid removing and installing the cowling a bunch while I try to find the right combination of parts.
The casper should fit but you will need to buy a spacer from them directly
You should have a look at removing those zip ties from the engine mount, dirt ,vibration will eventually cut through.
Chris RV 4 N1212R EAA Technical Counselor
I had a Casper adapter on my 4 with an O320 and dynafocal mount. I think I needed a 3/4" spacer to clear the mount if memory serves.
