Here is a very quick summary of what is new with the version 5 software:
AFS Enhanced EFIS Features
1. Enhanced Graphical G Meter with markers for min and max left of airspeed.
2. Enhanced Airspeed display with rolling digits.
3. new True Airspeed display box
4. Settable airspeed bug, knob or press knob to set to current.
5. Enhanced Altitude display with rolling digits and 500 ft markers.
6. Density Altitude display
7. Settable altitude bug, knob or hold knob to set to current.
8. Patent Pending circular DG Display
9. Enhanced Pitch display including de-cluttering rolling digital pitch markers
10. Wind indicator including speed, direction and crosswind component.
11. Automatic barometer adjustment for saved field elevation.
12. New style SD card status ICON
13. New style Battery status icon.
14. Split Screen for Check lists, no more loosing EFIS during check lists.
AFS Navigation Features
15. GPS driven HSI display including:
a. Track, Course, Waypoint ID, CDI, distance to WP, bearing to WP
b. NMEA and Aviation format serial data decoding.
16. SL30 NAV Radio driven HSI display including:
a. Current OBS display
b. OBS settable from EFIS display to SL30
c. Primary Frequency display
d. Nav source decoding
e. Bearing to active and bearing to standby.
17. SL30 NAV Radio Glide slope and Localizer display.
18. SL30 Radio comm. and nav radio tuning, the EFIS will pass through any GPS sent radio frequencies to the SL30 standby frequency.
AFS Moving Map Features
19. Unique Full Screen Map with Airspeed, Altitude and Engine Monitor display.
20. Split Screen Map, EFIS, Engine Monitor display.
21. AFS proprietary database.
22. Public and Private Airports
23. Obstacles and towers.
24. Airspace and vertical boundaries are drawn on the screen.
25. Intersections.
26. VOR?s
27. State lines
28. Airport Info display including:
a. Runway drawing
b. Traffic pattern
c. Frequencies
d. Fuel Info
e. Field Elevation
f. Pattern Altitude
29. Direct TO navigation lets the user select the airport using the data entry knob, automatically filters airports for remaining codes.
30. Nearest navigation brings up the closest 10 airports using the current zoom level.
31. Map displayed flight plan can be from external GPS or internally selected airport.
32. Display of current: way point: ID, distance and ground speed.
33. User adjustable zoom level with zoom scale arc display.
www.advanced-flight-systems.com/Products/AF-3000/AFS EFIS V5 Split screen.jpg
More pictures to follow, soon.
Rob Hickman
Advanced Flight Systems
