6A fuel sender gaskets
pgtuck
Active Member
Patron
I'm in need of gaskets for the S&W right fuel sender and the larger tank mounting panel. Vans show nothing for the gaskets. Is this a make your own out of cork gasket material? Thanks in advance
The overall concensus of builders (and I beleive the factory mechanics) is to seal both these joints with just pro-seal. The rubber gaskets that come with the fuel senders get soft with exposure to Avgas and eventually leak. The big access panel can be sealed with cork - but pro-seal alone works great. Most people never remove either of them, but if you have to, it isn’t that bad getting through the pro-seal with the right tools.
I got a replacement set from vans a gozillion years ago and made a set from cork after that. Ezturn/fuellube as a sealant and don't overtorque them
