gyoung
I've wanted a 3D printer to play with for some time but never had enough of an excuse to get one. Now I do so I'm on the hunt. I know there are a bunch of you using them but I couldn't find any threads on recommended printers. If there is I'd appreciate a link. If not, what do you recommend for a serious hobbyist to get started?
My excuse is way off the RV path. I'm starting a top overhaul on a 125 Warner radial for a 1940 Rearwin Cloudster I'm restoring. I will need cover plates to protect the rods when I remove the cylinders and to seal the crankcase so I can paint it. There are some other cover plates I'll need as well. I'm sure it would be more cost effective to draw them up and get someone else to print them but what's the fun in that? Thanks.
