2020 Pro Dynamic Propeller Balancer
MauleOwner
Member
Patron
2020 Pro Dynamic Propeller Balancer: this balancer package is complete with manual; cd; cables; accelerometer; propeller protractor; reflective tape; assorted mounting hardware; optical tach; etc everything you need for prop balancing except for a weight scale ($20 on Amazon) and AN hardware trim weight. The software is no longer supported by ACES but they will still calibrate it annually, needed for balancing certified aircraft and rotors. Certification is not needed for experimental aircraft.
Asking 2,000 You can pick it up at Oshkosh.
