I've got a new-to-me RV6 (built in 1995) that I've been carrying out transition training in with my instructor. A couple of days ago while in the pattern our voltage spiked up to around 15.5V and stayed there. We did a bit of troubleshooting and parked the plane. I removed the voltage gauge and with a variable power supply verified it is indeed correct, and if anything reads about 0.3 V low.
Yesterday I removed the cowl so I could have a look at the alternator. I don't recognize the alternator and none of the RVs nearby at my field have this type either, they all have a B&C unit. Here are a couple of pics, Google suggests a 1978 Land Cruiser but I checked that and it isn't a match. I suspect this is a common car alternator pre-1995, as this thing looks like it has been on the plane for a long time. Anyone recognize it and can ID the car year/model?
I might have it rebuilt locally or possibly source a new one. In hindsight, I probably didn't need to remove it at all as I think this system is externally regulated and the failure mode points toward the regulator, but I don't think it'd be a bad idea to replace this one. I think it's got 1500+ hours on it.
I think the picture I took below is the voltage regulator but I have yet to remove it and ID it. Again, none of the other RVs I'm connected to have this sort of regulator, if that is what it is. Anyone have any insight on it?
Sorry for the ill-informed questions here. I only had time to remove the alternator yesterday and am headed back to the field today to discover more.
Ron
Ron
