Alternator identification / voltage regulator - 1995 RV6 Build
Ron Earp
I've got a new-to-me RV6 (built in 1995) that I've been carrying out transition training in with my instructor. A couple of days ago while in the pattern our voltage spiked up to around 15.5V and stayed there. We did a bit of troubleshooting and parked the plane. I removed the voltage gauge and with a variable power supply verified it is indeed correct, and if anything reads about 0.3 V low.
Yesterday I removed the cowl so I could have a look at the alternator. I don't recognize the alternator and none of the RVs nearby at my field have this type either, they all have a B&C unit. Here are a couple of pics, Google suggests a 1978 Land Cruiser but I checked that and it isn't a match. I suspect this is a common car alternator pre-1995, as this thing looks like it has been on the plane for a long time. Anyone recognize it and can ID the car year/model?
I might have it rebuilt locally or possibly source a new one. In hindsight, I probably didn't need to remove it at all as I think this system is externally regulated and the failure mode points toward the regulator, but I don't think it'd be a bad idea to replace this one. I think it's got 1500+ hours on it.
I think the picture I took below is the voltage regulator but I have yet to remove it and ID it. Again, none of the other RVs I'm connected to have this sort of regulator, if that is what it is. Anyone have any insight on it?
Sorry for the ill-informed questions here. I only had time to remove the alternator yesterday and am headed back to the field today to discover more.
Ron
Ron
Looks like the Denso which is probably the original alternator on my 1980 RV-3 with about 1500 hours now. I went through a number of controllers before I finally installed a Ford regulator from a 70's Crown Vic; no more problems for years.
Most likely the 35a alternator Vans sold for many years. You can replace it with the following alternator:
1978 Honda Civic CVCC, no air conditioning; common number is 14184
The replacement will most likely have a fan that rotates backwards on the Lycoming but it will cool just fine. A blast tube directed at the rear of the alternator is worth installing.
A good regulator is the VR166 from a mid-70's Ford LTD.
I've been flying this combination on the RV-6 since 1999.
The 1980's called -- they want their alternator & regulator back.
Ancient ND -- 20000 - 21000 series, and someone removed the fan from the front of it. Plug code is PL-3601, Top is "E", Left is "F", Right is "N" --- "E" goes to a Lamp, "F" is the field supply -- the yellow wire back to the regulator, and "N" is the center tap of the stator windings. But I could be wrong.
Buy a B&C LX60 alternator and LR3E regulator and go fly.
E is a ground (E = earth), F is the field. I always run the E lead to a grd point for security. Unsure, but think N is a stator tap, but I never connect to it.
E is a ground, F is the field. I always run the E lead to a grd point for security. Unsure, but think N is a stator tap, but I never connect to it.
On second thought, I did connect N to the stator feed on my transpo when troubleshooting an issue. It worked fine, so assumed it must be a stator tap. possible it was a lamp drain, just didn't create an issue for me. i always thought the logic for a warning lamp came from the reg, not the alt.
Ron
From an older post. That looks like the 35amp 14184 alternator that Vans sold for many years back in the day, it is externally regulated. I have been flying this alternator on mt RV-6 since 1999. Use the 14184 number at any auto parts store to find a replacement, they were originally on a 1978 Honda Civic CVCC, no air conditioning. A regulator for a 1975 Ford LTD works nicely with this alternator, generic number is VR166.
Vans sold these with the fan removed as in your picture. The one pictured appears to have a larger diameter pulley to slow down the RPM. Now it is often replaced with new Part Number 14684N Vehicle Fitment Make Model Years CHEVROLET SPRINT 1987-1988 GEO METRO 1989-1993 SUZUKI SAMURAI 1986-1995 SUZUKI SIDEKICK 1989 internally regulated so the external VR is not used. The pulley is smaller than the one pictured so a different belt will be required or the larger pulley moved to replacement alternator. The Lester part number 14684N is available online and at many local auto parts stores. Lots of references to both these alternators if searched on this forum.
Hey y'all, thanks for all the replies and guidance. Very helpful. I removed the regulator this morning on the wire wall. Date code was 7/94, adjustable pot on the back too.
I was able to find the parts at Advance Auto / Carquest.
The votlage regulator I was not able to find with the VR166 number, nor would it pop up on a Ford LTD application, at least not one that looks like mine and in the order above. But I found it via searching "12V automotive regulator with single field wire input" since that is what it has and the one above RAC2157 popped up, which looks exactly like mine.
The alternator is definitely the Honda CVCC unit from 78-80, and they're on sale for $25! Uprated 10 amps to 45 amps, but I think that is fine. I'll try it out although I suspect my alternator is actually fine.
I ended up ordering the parts for delivery as I couldn't find them in stock around Raleigh, at least not the regulator. The alternator was up in Knightdale but since the regulator was nowhere to be found I just ordered them for delivery.
So, I'll get the parts in and report back with what I learn. Thanks again!!!
Ron
Sounds like a great deal. Alternators are simple enough but not sure I would use a $25 chinese in my plane, may want to stick with the one you have and overhaul it, usually brushes are all that go bad and those are simple to remove replace. If that VR proves good may want to order a back up to carry with yu. I bought a lifetime warrenty new alternator internal regulator for my F-150 from autozone and 7 months later learned why they are lifetime warrenty... chinese junk voltage regulator. I will stick with genuine Denso for my plane
Sounds like you are all set, but for sake of completion, here is the alternator I installed on my RV6 in 1996 and replaced in 2020. I think you will find it is exactly like the one you removed. This was the Mark Landoll "lightweight" alternator. I'm pretty sure he bought the 14184 Honda alternator and did some beefing up of his own.
Also, a replacement voltage regulator like your original:
Please let us/me know how the VR you ordered works out. I'm always looking for other options just in case.
I'll let everyone know how the parts are and so on. I have an alternator rebuild shop where I grew up in Burlington NC that does great work with high quality rebuilds for special purposes. So I might have them rebuild the one I have and use it as a primary or keep for a spare, either way having a backup on the shelf is the goal.
Denso used to make their alternators in Tennessee but a few years ago that plant announced it was shifting to EV components after over 100 million alternators produced. They still do alternator rebuilds in California, so it might be the rebuilt "new" one I bought for $25 closeout is a Denso rebuild from CA. However, it looks like new ones are being made in Taiwan, China, or India.
I'll see what I end up with from Carquest on the alternator and regulator.
Here's some additional information -- might be helpful.
Was there no other plug(s) on that regulator -- just the wire connected to the screw post?
The field wire from the alternator connects to the post on the regulator. On the backside of the regulator a wire goes through my firewall and is connected to a wire that I presume is a 12V from the buss to monitor voltage, but I haven't actually traced that out. I know it works fine, so was planning to put everything back together as it was.
Okay, this alternator is not a replacement alternator for the 35A unit from the Honda Civic CVCC, not at all. The regulator I'm not sure about yet.
After additional searching it appears that RockAuto does have the proper alternator so I've returned the one I ordered from CarQuest and have one from RockAuto on the way. Meanwhile, my original is at the shop for a rebuild. Will see what RockAuto turns up and report back.
Now, in doing more reading and research about external regulators I've learned about A and B circuit regulators. Here is a good video on it:
Essentially you can figure out how your system is setup by checking out your alternator. Measure the resistance between the field terminal on the alternator and the alternator case (alternator disconnected from wiring):
  • If you get a reading of 3 to 6 Ohms: The alternator's internal brush connects the field coil straight to the grounded case. This confirms you have a B-circuit alternator.
  • If you get an open circuit (OL / Infinite Resistance): The field coil is insulated from the case ground, meaning it requires an external ground source to operate. This would indicate an A-circuit.
I get about 4 ohm on my alternator indicating a B-circuit type regulator is needed, like the one that Dave Binkley posted above, which is indicated to be a B circuit type regulator. So, I am going to order one of those that he posted and return the one I have.
View attachment 122943View attachment 122944
azrv6,
Small word of caution here: I replaced one from my -4 built in 1996. It was identified as a Denso used in fork lifts.
The caution is be very careful the pulley aligns perfectly on the belt.
TLAR (that looks about right) is not good enough.
My was offset a slight amount and it burned the bearing out within 30 hours of use.
Daddyman58
Why not just use the VR166 Ford regulator that has a proven 35+ year field history with the Honda Civic alternator? It is inexpensive and available everywhere.
Here are the connections for the VR166:
"I" is not used
"A" goes to "S"
"S" goes to aircraft bus (12v)
"F" goes to alternator field
Be sure the case is electrically grounded.
A & S is the input power source for the regulator circuitry, as well as the Voltage sense feed. Best practice is to feed this from a Fuse or CB and most also want a switch in the loop to turn it on and off, which is also a best practice; Stopping an over voltage event is just one reason to have it. Feeding it from the B lead is a big mistake in my opinion, as a dead short will require the wire to fully melt before breaking the circuit. Electrical appliances like this should always be fused in some way and the B lead is unfused; alt will provide an endless supply of power as long as there is current on the F lead. it will also feed from the battery where the B lead is attached and if fused, is probably 80A.
The text description is best, the photo was just to reference the terminal arrangement, guess I should have noted that. I have the voltage sense lead running through a panel breaker on my RV-6 but no switch since I have an OV module. The module will activate far quicker than I could notice the over-voltage and find the switch.
sorry, only noticed text in pic. didn't notice the main body.
