Gil - I believe if we started a discussion of who's had trouble with 'X' entry procedure you'll find everyone will pipe in with different answers.
I've had trouble with the OB, the 45, the straight-in, crosswind, autorotation, circle-to-land, PAR hand-off to tower, and even when all of these have worked perfectly I've still had to wafe-off the landing because someone decided to T/O while I'm on short final...
Nobody is claiming the OB is perfect or any better than any other entry under all conditions, just that it is a valid entry and as safe as any other when executed properly. Nothing more, nothing less. Certainly you see the logic in this?
