I made some ring compressors for the 5.125" bore Lycomings to compress the rings when installing the pistons with the con rod still attached, out of Aluminum tubing for a friend. 6" o.d. x .5" wall will do it.
I am not a machinest by trade but I do have a really nice tool room lathe (Monarch 10EE w/updated VFD drive), but no mill to cut the slots - on my own on that one.
So I made a "fixture" to securely hold the rings (after machining) while I rough cut them on my Aluminum cutting bandsaw. Still in the fixture I "milled" them on my wood router with carbide tipped blades with ball bearings to maintain a smooth finished surface. I got a red tagged cylinder from LyCon - practically my neighbor (25 miles away) and used it as a go/no go gauge. Everything fits, but have not given them their "baptism" under fire yet. We'll see ...
I looked up LyComings MSRP for P/N 64712 - Ring Compressor 5.125" bore just for s***s & grins. Holy S**t Batman - they listed it for $9,280!
And no, that's not a typo - I looked up that part number from several suppliers and got the same answer. Lycoming does not want you to have one of these, for whatever reason ... pick one.
YMMV - and there are certainly other ring compressors that will work, this just happened to be what the "customer" spec'd ...
