simpsonstu
Hi All,
Been a little toasty in the UK recently with temps around 80 F. With full throttle on take off the No1 cylinder indicates the hottest but 1,2,4 reach 1550F the rest just under 1500, pretty much stays that way even when RPM reduced to 2500 until airflow increases to around 125kts indicated. The No1 CHT also peaked momentarily at about 420F albeit for a few seconds, which I have never seen before. Fuel flow on take off is around 88 l or 23 ish gallons an hour, so it’s getting enough fuel on take off according to Vics video on base leg.(Edited to say having rewatched it’s not)
Cruise is all fine but I have noticed I cannot move the mixture very far without EGT’s going into the high 1500’s again, so leaning is almost a non starter, it used to lean absolutely fine with a fair amount of movement to see any spikes.
I appreciate CHT is the important one and the no1 is normally the hottest but surely I shouldn’t be seeing these high temps on take off with temp outside in the 80’s F. Is it a case of checking fuel nozzles, baffling around the engine or a hazard of a 540 on a hot day, I never noticed any of this with external temps in the low 70’s. Or poor control of RPM etc after take off? I do not use the Dynon leaning setups.
Sorry rubbish picture but 225C is 437F, 840 is 1562, the peaks.
Cheers Stu
Cheers Stu
