What Larry ^ said.Not true, but some epoxy primers do have stronger adhesion to metal by design and therefore helpfull when working with Alum. The paint can grab better to the primer than the tougher surfaces. Paint is porous and will allow corossion on base metal over time. Primers primary role is to prevent that, as well as being a stronger base (different properties). Several other reasons/benefits also.
And paint is better at protecting the primer and metal from corrosion than the primer is. My 1993 Super Cub was primed and then clear coated on top of that. The Super Koropon primer failed on the space shuttle until they discovered this.Primer sticks to bare metal better than paint does. Paint is really good at sticking to primer.
I just flew with an ex A+P from a legacy airline. We were talking paint. He asserted that you have to prime the surface before painting or else the paint won’t stick. What I’ve read on here goes against that…I think.
Thoughts?
Did someone wake up with a poopy diaper?There are 448 threads over 21 years about priming that dispel the notion "What I've read on here goes against that...I think"
A
There is a window for doing wet on wet. Usually 24 hours or less. I prefer to let the primer cure then sand it. You get a better, smoother finish that way. IMHO.And paint is better at protecting the primer and metal from corrosion than the primer is. My 1993 Super Cub was primed and then clear coated on top of that. The Super Koropon primer failed on the space shuttle until they discovered this.
Read the manufacturer's instructions, sometimes there is a 'window' for applying the topcoat.
D
^_ this is why I Never say: “Oh, I slept like a Baby”Did someone wake up with a poopy diaper?
