Very interestingInteresting too is that they no longer use the Beringer
Weird to be honestAlso, interesting jack pad arrangement.
It looks like if you get a flat tire the brake caliper hits the ground? Hmmm.Tire install.
So this is still the same Fuselage as last year?Just looked at it at the Vans booth. No baggage door yet so I would guess they still have some fuselage iterations.
Definitely has the jack screw. I could see under the horizontal stab where there was a spot to cover a gap where the jack screw is and can slide.It sure looks like it- I believe they have the announced jackscrew trim system and final tail feathers installed, but there is still evidence in the roof of the door pillar area of the original flap handle pivot bearing, which has been there for a while.
