Do i need a compass?
why cant you taxi on a specific gps heading, accounting for magnetic deviation, and swing your compass like that? really seems more accurate than trying to lign up your airframe up on a compass rose.
It’s just not the official way. There is a small issue that you do need to taxi some distance in a straight line to give the gps a chance to figure out the ground track. And then be able to stop and park for a bit while you twiddle the adjustment screws. IMHO this should work okay.
And when stopped, you need the GPS course to stay steady, but there's no guarantee it will...it depends on the Kalman filter used. The computed GPS position, which is all that GPS "knows" (well, that and time), moves around (everything else is computed from that...velocity, heading, etc.). But without knowing the details of the Kalman filter, you don't know how heading is computed and estimated.
Okay, trivia time:
Suppose I have a VOR on my field. I taxi around until my perfect accuracy SL30 nav says I'm on the 270 radial from that VOR. I can see the VOR, so I turn the plane to point the nose right at it, and swing the compass to 090. What's wrong?
The airport diagram tells you the actual heading of the runway and also the local deviation. In a pinch you can use that for a compass rose in two opposite directions.
So, here is my challenge with magnetic compass: Environment! Any suggestions? The over 50-100 degree deviation isn't consistent on all headings.
Wrap it with nickel sheet metal. Worked for me. I used to have an old navaid autopilot right underneath my compass. My compass would only swing 270° no matter what. Wrapped the navaid in nickel sheet metal and I had a perfect compass swing.
Edit… you’d actually want to wrap the metal things around the compass, not the compass.
Not enough information to know how you compensated for the offset between the aircraft VOR antenna position and the axis of aircraft rotation.
We'd need to know the distance of the aircraft from the VOR, and that offset, to know if it introduces a significant error.
This is a trivia question! Assume you know you’re right on the radial, you made a zero distance turn to point directly at the station. What is still wrong?
Okay, trivia time:
Two words: VOR and declination.
Heaven only knows the last time that VOR was aligned. It can easily have been 30+ years for many VORs.
Ah! 😕, I was hopeful until you did the edit. 😂 I think that it is essentially the airframe/cockpit as I really don't have any electrical equipment anywhere near it - everything is steam gauge and the radio is underneath on the floor between the legs .... I wonder if you wrapped the compass with it if it would block the magnetic field to the compass....? idk 🤷🏻‍♂️
i think swinging a compass is in the same boat as an ndb approach...........not very precise. i would think the variance in a gps signal is nothing compared to the errors involved in swinging a compass. like is the airplane lined up exactly on the heading you want?
True, but it won't satisfy the requirements for a DAR or FSDO to issue an AWC.
The problem comes when some ill-informed inspector believes that you HAVE to have a "wet compass" despite your EFIS and its own magnetic direction indicator...
RV7A Flyer,
My DAR believed it was a must have item.
I put one in somewhat begrudgingly.
During 1st flight I had a total black-screen incident.
Even then, I did not have to have it as I was familiar with the area and in VFR conditions.
I found it antiquated that the only 2 working instruments in my "new" plane was the wet compass and my watch.
Real old school for a modern glass cockpit.
Daddyman58
in the FD they list the declination which was used to align the the VOR radials.
eg
MARTINSBURG (L) (L) VORTACW 112.1 MRB Chan 58 N39º23.13´ W77º50.90´ 286º 6.3 NM to fld. 600/7W
Compare that to the current declination https://www.ngdc.noaa.gov/geomag/calculators/magcalc.shtml or on sectional. It is 10° for MRB. so the radials are 3 degrees off. Do mental gymnastics to figure out where you actually point at when looking at the VOR from a known radial. Get it wrong every time 😂
eg
My instructor used to call it the built in crosswind. We have a couple near me that are >5 deg off. One was last aligned in 1973.
