Free Flight Data Viewer for Dynon and Advanced Flight Systems Aircraft
donwhite
I'm New Here
I built this website for my aircraft and want to share it with you now.
DynonGraph.com is a free, browser-based tool built for owners and builders of experimental and homebuilt aircraft equipped with Dynon avionics or an Advanced Flight Systems (AFS) EFIS. Simply upload your Dynon USER_LOG_DATA CSV or Advanced Flight Systems ALD export and instantly see your entire flight visualized: RPM, cylinder head and exhaust gas temperatures, oil temperature and pressure, manifold pressure, electrical system performance, airspeed, altitude, vertical speed, fuel flow, and your GPS flight track plotted on a map — even in 3D. Use custom graphs to plot any combination of parameters side by side.
New: DynonGraph now supports Advanced Flight Systems (AFS) EFIS log uploads — simply drag in your ALD file — and lets you build and save custom graphs to compare any combination of flight parameters side by side. DynonGraph also supports pilots worldwide — not just the US N-number format. Registration prefixes from over 200 countries and territories are automatically recognized (Canadian C-, Australian VH-, British G-, and all other ICAO-standard formats), so the country of registration is shown alongside your aircraft title and confirmed when you upload.
DynonGraph automatically detects each individual engine run within your log, flags out-of-range readings like an over-redline tachometer or low oil pressure, and lets you export a clean PDF for your logbook or maintenance records. Create and save custom graphs to compare any parameters that matter most to you. There's nothing to install and no account to create — your data stays private and is only used to generate your own charts.
Whether you're troubleshooting an engine problem, tracking trends over time, or just want a better look at your last flight, DynonGraph turns your raw Dynon log file into clear, actionable graphs in seconds.
DynonGraph works just as well on your phone or tablet as it does on a desktop — every chart and control is touch-friendly, so you can review your flight data right from the hangar or flight line.
Available in English, Spanish, French, Italian, German, Portuguese, Japanese, Mandarin, and Hindi — use the language selector in the top-right corner to switch.
by Don White, creator of: OurChapter.org, EAABuildersLog.org, YEDay.org, FlyingStart.org, GoClub.us, Searey.Us and many more.
I just added a new function to this DynonGraph.com website: DynonGraph now also displays LOP (Lean of Peak) and ROP (Rich of Peak) mixture state directly on the EGT chart — teal shading for LOP, amber for ROP, and a dashed line marking peak EGT. For flights where the Dynon lean-assist feature wasn't active, DynonGraph automatically infers lean-to-peak events from EGT and fuel flow patterns.
Been playing with Don's new toy and it's very nice. Dropping in my Dynon info for my IO-540 and there it is. Yesterday I asked about LOP and ROP indications and boom...in 10 minutes he had added the functionality. I have been using the Savvy analysis and it's good, but this is better. It's free, we can't complain.
Just added a Privacy function - Your exported PDF now leads with that Flight Summary as its own first page, ready for your logbook. When uploading a log, you can also mark your tail number as private so it stays hidden from the public aircraft list — and you can still search directly for a tail number even if it has been marked as Private.
New: DynonGraph now offers AI-powered Engine Analysis — click the Analysis button on any flight to receive an instant engine health report covering cylinder temperatures, mixture efficiency, oil system performance, and personalized maintenance recommendations, all generated by AI. Free users receive 3 analyses per week.
I've been thinking about building something like this for the Garmin side of the fence. This looks incredible, very well done - and a great resource for the community.
It will/would be interesting to see some of the data in a larger perspective (average averages, or average maximum CHTs, etc). I
