Engine mount replacement for the RV 3
J29racer
Above all the rest of the stuff going on with the RV 3 I have a separate issue and that is an engine mount repair or replacement. After talking with Van they tell me there are two types Dynafocal and Conical type I have an old O-320 engine and new motor mounts, so I would like to keep those. Does anyone have pictures of the two types and are the bolt alignment to the firewall the same for both of them.
It should be clear when you look at the engine. If the bolt to the engine and the isolators is parallel to the crankshaft, it's conical. If it's angled inward at the foreward end (and pointed down for the upper ones and up for the bottom ones), it's Dynafocal.
But note the there are two types of Dynafocal ones. One is in general use, the other, I think and could be wrong, used n Twin Comanches.
Dave
Well thanks for that the engine mounts are pointed in sort of focusing on a common imaginary point in the center half way up the engine if you know what I mean.
The two types of mounts are dynafocal I (one) and dynafocal II (two). The “one” is focused at a point about at the forward end of the crankshaft.
The “two” is focused at a point ahead of the crankshaft forward end allowing for the space of the propeller.
I hope I am describing that right. The engine that I have came from a Twin Comanche and I sent it into Divco for “repair” and remade as conical. The original designation: IO-320 C-1A
It had aft mounted fuel injection with a 45 degree intake adapter to bring air in from the side of the engine nacelle.
Drawing 29 of the RV3 plans (attached) shows side views of both the conical (left side of drawing) and dynafocal (I) mounts (right side of the drawing). Both examples in this drawing attach to the firewall at 6 points (as does my RV-3B Dynafocal mount).
There may have been other engine mount designs for some “early” builds (no two RV-3’s are identical!). I know of an (early) RV-3 which had a conical mount with only 4 attachment points at the firewall, but I’ve not personally seen one.
Peter
Peter
Yes the two attachment points near top of gear leg sockets was an addition to the original design. Should also include F-312 (angle and web) shown on drawings #20, #24 and #25 but not on drawing #21. I did that on my RV-3A back in '99. Unfortunately the builder of my 2003 RV-3B omitted that (custom engine mount). That modification is nice because it creates a nice area for battery or other things. Basically it transfers gear leg fore-aft movement forces to bottom of main wing spar.
  • Dwg20-26.pdf
    Dwg20-26.pdf
the odd dynafocal was used only on the Twin Commanche and Wing Derringer. The Twin Commanche's all had special Hartzell props with long built in extension. The different mount angle was to deal with issues created by the long extension. Twin C are either 0 320 B or C and all have aft mounted fuel injection.
Just catching up with these drawings. Yes my mount only had 4 attachment points. I have ordered a new mount. The Dynafocal version 1. I hope that is it. If anyone can explain the difference I would love to hear it. Also does anyone know what the other two attachment points attach to?
The lower left quadrant of RV-3 Drawing #24 shows the large “ribs” that go between the rudder pedals and attach to the firewall with heavy angle aluminum - the two extra attach points go in to those.
Do you know what the difference is between version 1 and 2 of the Dynafocal mounts
Thanks so much for this drawing. I will have to see how hard it will be to retrofit my RV 3 for this new engine mount. Can you send me a better picture of the inside of the firewall with the cross bracing.
Well this is quite interesting after my order from Van’s for a new engine mount for 5K they now tell me that it’s going to be like 9 months lead time. This is crazy! Anyone out there with any ideas? Maybe a group purchase to get a better commitment. Any kits out there that want to give up there motor mount?
A good place to figure out the type1/2 mount is https://en.wikipedia.org/wiki/Lycoming_O-320 you can walk the lineage and it will show you which mount should be on the engine. What is the engine type on the data plate?
Also what is wrong with the existing mount? I recently repaired an RV-4 mount that was damaged by hard landings, basically had to replace the cross member and some of the mounts that had torn. Much easier than fitting a new mount as you have to match drill the gear legs or get new ones as well.
Well I wanted to get the new version and yes you can repair and may have to as the new one is not available
I’ve got a new mount. My 3 has a “unique” center section so I repaired the original mount and kept the new one as a spare if I ever wanted to cut it and re-weld it to fit mine. I had it powder coated yellow before realizing it wouldn’t fit. I suppose the new way is not to powder coat, but I didn’t realize that at the time.
So do you have the mount available? Can you text me my number is (860) 857-5249. Yellow is fine!
Yes, it is the new, six point mount. I think we paid 2,000 for it a few years ago but ended up reusing the old one since it wasn’t cracked and the original builder had modified it. I’d like to get out of it what we paid. Hopefully this will help someone in need of a new mount…
