If it's just drill out old rivets and pop rivet new....I'll take one. My current is pretty beat up.I'm tooling up to build a batch of one piece stainless steel exit ramps to replace the standard aluminum sheet ramp on the -8. It is stiffer, far more crack resistant, and fireproof. Looks marvelous too. $300 each delivered (49 states). Who wants one?
I don't mind, but shipping is on you.Yep! Put me down for one!
If you’re willing to ship to the UK?
It's an AWI 4-into-1.Where did you get that exhaust?!?
Yes.Will it fit the 8A
Starts off as the same part from Vans but has to be cut to accommodate the nose gear. See plans. Unless he’s willing to do that you’ll be cutting it yourselfWill it fit the 8A
I kinda want one and I don’t even have an 8!I'm tooling up to build a batch of one piece stainless steel exit ramps to replace the standard aluminum sheet ramp on the -8. It is stiffer, far more crack resistant, and fireproof. Looks marvelous too. $300 each delivered (49 states). Who wants one?
Thanks Dan.I don't mind, but shipping is on you.
I am in "lust" with your exhaust pipe!I'm tooling up to build a batch of one piece stainless steel exit ramps to replace the standard aluminum sheet ramp on the -8. It is stiffer, far more crack resistant, and fireproof. Looks marvelous too. $300 each delivered (49 states). Who wants one?
DanH,I'm tooling up to build a batch of one piece stainless steel exit ramps to replace the standard aluminum sheet ramp on the -8. It is stiffer, far more crack resistant, and fireproof. Looks marvelous too. $300 each delivered (49 states). Who wants one?
I have a brand new aluminum ramp, untouched, still in the blue film. I purchased it from vans a couple months ago to use as a template.Do any of you have a stock aluminum ramp which has not yet been attached to the airplane?
Yes. I have one.Do any of you have a stock aluminum ramp which has not yet been attached to the airplane?
Thanks, got it covered.Yes. I have one.
