Obstructed tank vent
Dugaru
Friend
I noticed one of my fuel tanks was gurgling quite a bit and filling slowly. I suspected a blocked vent, but the outlet near the firewall looked okay: I could see that nothing was covering the little mesh screen that had been installed over the end of the vent tube, presumably to keep out insects etc.
But then I looked closer. The screens had been attached with some sort of goo/rtv/sealant. Apparently, over time that material degraded and flowed into the mesh, giving the vent opening a serious case of atherosclerosis! This problem wasn’t easily visible when the screen was installed over the dark tube interior, but it was easy enough to see when held up to the light (see attached photo).
Lessons:
1. Innovations to increase safety can create their own problems.
2. Inspect vents carefully, preferably with a flashlight.
I noticed one of my fuel tanks was gurgling quite a bit and filling slowly. I suspected a blocked vent, but ….
I am puzzled that a blocked vent would lead to ‘filling slowly’. The open gas cap area is huge compared to the vent size, the air should easily exit there. ??
I can’t fault your physics. All I can say is that it gurgled a lot and you had to top it off slowly or you wouldn’t fill it. Still gurgles but seems to fill faster now. Perhaps not? I suppose it’s possible I serendipitously found a potentially dangerous condition after misdiagnosing the actual problem. 🤣
I had the little screens on there originally but took them off as the vent hole is barely larger than the screen gauge, plus it's difficult to proseal it on without having the goo obstruct (possibly what happened here). One data point anyway.
