Thanks for the quick reply. What “ Function Code “ should I check ?The FAA has an App for That!!
FAA-Designee Management System
The Designee Management System, DMS, web-based tool, designed to standardize the management of designees.designee.faa.gov
You’re looking for a DAR-T
You didn't say which category.Thanks for the quick reply. What “ Function Code “ should I check ?
Thanks Mel .You didn't say which category.
For FSDO (DAR-T) function code would be 147 for EAB prop, 148 for EAB turbine, 149 for EAB rotorcraft, 157 for E-LSA, 158 for lighter than air, 159 for powered parachute & weight shift.
PM sentLooking for a DAR in the Daytona/ St Augustine area . Have a new build that needs inspection
Arnold is 1 of the 2 DARs in Florida… and he’s too busy at this time .Arnold Holmes is out of Leesburg Florida and he will travel. I’ve used Arnold several times and have recommended him to many others.
