Deburring Tools
raabs
What do you all recommend to stock up on for deburring tools for the 15?
Inbound wings in next 30 days.
I got a tool kit from Cleaveland tools which included a speed debur (buy an extra bit so you have a separate bit for fibeglass) and a debur handle and kit from Shaviv. I think ACS also carries that handle and bits.
Cheers.
Cheers.
Thanks. I have a bunch of scotchbright pads and a few deburring tools for drilled holes etc. How about scotchbrite wheels for skin edges, lightning holes and edges of parts? What works well on die grinder dremmel or bench grinder?
Everything in this picture. Lol. Im in the middle of it now.
Die grinder
1" wheels
Dremel
2 x 6" wheels
Sandpaper
Files
I don’t think I used the wheel at all. I have a polished skin so I was being very cautious. I did use the pads for ribs and maybe a bit on the skin edges. They had an edging tool that put a chamfer on the skins. It worked well but a bit tricky to use. It doesn’t seem to be in their catalog now. It’s available at acs
It avoids riding up on the skin if you are trying to keep it pristine but it also grabs so you need to practice using it.
