I’m looking for some advice regarding a fuel tank issue on my RV-8.
My fuel tanks came assembled as part of the QuickBuild wings. About three months after I first started adding fuel for tank calibration and testing (before the airplane ever flew), I began noticing paint bubbles forming on one of the fuel tanks.
The bubbles appear to contain fuel and are forming between the tank skin and the paint. Most of them are centered around rivet locations, which leads me to believe that I may have a tank that was not properly sealed during assembly. The opposite tank shows no symptoms whatsoever.
I’m attaching photos of what I’m seeing. At this point I probably have 10–12 affected spots, with some of the bubbles reaching up to about 1/2 inch in diameter.
My question is: Is there any proven method to seal leaks like these without having to work from inside the tank? I understand that I’ll need to completely drain and defuel the tank, but I would really like to avoid disassembling or opening it if possible.
Has anyone successfully repaired this type of leak from the outside, perhaps using an approved sealant injection method or another technique?
Any experiences or recommendations would be greatly appreciated.
Thanks!
Thanks!
