I haven’t swapped one personally, but I have an IFD 550 in my Beech. A friend told me the avionics shop only had to wire one additional thing to get it working, so he said it should be quick and relatively inexpensive.
I can’t say enough good things about the Avidyne units. They are extremely capable. In my experience they’re more capable than Garmin in a lot of ways, but they can be a bit tricky when you start mixing them with other avionics. I had no issues getting mine to work with G5s.
Avidyne also has an iPad trainer that I highly recommend using. It’s also worth watching a few videos on how to get ADS-B weather and traffic to display properly on the unit. You’ll need a receiver that supports the Capstone protocol, like a Stratus 3 or 4, or a Stratux.
Like others have mentioned, the IFD100 app is excellent. It gives you almost full functionality on your iPad as if you had a second IFD in the cockpit. The only limitation is that you can’t switch comm frequencies from the app, but you can still load them easily.
As I say all of this, I have a Garmin GPS 175 in the mail to make my -8 IFR. I’m looking forward to being able to punch through clouds, but I will miss my Avidyne dearly
