And sometimes to over flowingI always use something. All it takes is one misaligned nutplate to fill that cuss jar!![]()
So say you cant use a squeezer and you need to use a rivet gun, do you use some kind of special screw without a head to give you enough room to rivet ( it is only 3/32 but still, the flush rivet set is about 1 inch wide ) ?I always use something. All it takes is one misaligned nutplate to fill that cuss jar!![]()
Maybe. I've used a gun/bar, squeezer, or whatever to set one rivet. Once one is set, the nutplate shouldn't move.So say you cant use a squeezer and you need to use a rivet gun, do you use some kind of special screw without a head to give you enough room to rivet ( it is only 3/32 but still, the flush rivet set is about 1 inch wide ) ?
Use pop rivets, they take very little to counter sink and you can easily mount them anywhere. The rivets need not be structural their only job it to hold the nut plates in postion and not allow it to rotate.Maybe. I've used a gun/bar, squeezer, or whatever to set one rivet. Once one is set, the nutplate shouldn't move.
FWIW - I use an NAS #3 Oops rivet for nearly all the nut plates. I also use a cut short SHCS (socket head) to mimic the installed bolt. I don't dimple for the nut plate attachment rivets - instead I just lightly countersink with the CS tool and install the Oops rivet, set with a squeezer if possible. The SHCS makes it easy to get the squeezer in place. I don't mind using Oops (NAS) rivets here because once the connection is made up - the rivets have little consequence.Hi,
When installing a nut plate , say K1000-3 for AN-3 bolt ( and assuming properly prepared holes ) - when riveting or squeezing , do you actually insert a bolt to keep the nut-plate aligned or do you just use clecos to hold the nut plate
A slight slip-up while setting the rivet ( usually with a squeezer) that results in the rivet tipping slightly, often displaces the nut plate slightly. Having a fastener threaded into the nutplate will keep it aligned in those cases.I used a nutplate jig to drill my rivet holes and never had any issues with misaligned bolt or screw holes.
I also use NAS1097AD3 rivets exclusively for any nutplate mounted to thin material. Dimple countersinking nutplates and the nutplate attach holes greatly increases the probability of the nutplate tilting or displacing while setting the rivets, because the dimples do not nest together 100%. If the shop head of the rivets doesn’t form perfectly symmetrical, it tends to roll the nut plate slightly on the dimple it is nested against.FWIW - I use an NAS #3 Oops rivet for nearly all the nut plates. I also use a cut short SHCS (socket head) to mimic the installed bolt. I don't dimple for the nut plate attachment rivets - instead I just lightly countersink with the CS tool and install the Oops rivet, set with a squeezer if possible. The SHCS makes it easy to get the squeezer in place. I don't mind using Oops (NAS) rivets here because once the connection is made up - the rivets have little consequence.
Try it on some scrap and see if this method works for you. I didn't invent it but learnt it from another expert builder.
YesAre there other flush pull rivets besides the cherry nut plate rivets available?
and a small assortment of washers available. No need to thread the fastener all the way thru or even into the NP locking feature. As for the fastener, a cap screw is kinda optimal many times. Small(er) head, no cam-out, etc.For the smaller sizes, I keep a screw on-hand with a ground down head to reduce the diameter and cut length so only a couple of threads engage in the nutplate. Then it’s easy to fit the nutplate and centre the squeezer on the rivet.
When installing new nutplates, I used the floating type so even when the bolt hole was misaligned, the floating action allowed the bolt to center find the nut.Hi,
When installing a nut plate , say K1000-3 for AN-3 bolt ( and assuming properly prepared holes ) - when riveting or squeezing , do you actually insert a bolt to keep the nut-plate aligned or do you just use clecos to hold the nut plate ?
