One location I had not consideredI didn’t want to lose any fwd baggage space except the tank in the lower front baggage area
Pump is mounted on the firewall to the left of my left foot. Works great and completely out of the way. Fitting through the firewall is just to the left of the pump.
Mike very interesting set upWe installed a 4 gallon aluminum tank flush with the baggage compartment, it is strong so can load anything on top of it. Pump and solenoid is mounted below it. The pumps runs both ways so it is filled from outside with a fill switch in the baggage compartment. Has a vent/ over flow near the fuel tank vent, very clean installation.
View attachment 119261View attachment 119262View attachment 119263View attachment 119264
Nicely done. Source for tank?We installed a 4 gallon aluminum tank flush with the baggage compartment, it is strong so can load anything on top of it. Pump and solenoid is mounted below it. The pumps runs both ways so it is filled from outside with a fill switch in the baggage compartment. Has a vent/ over flow near the fuel tank vent, very clean installation.
Thank you.Nicely done. Source for tank?
Is there support below the tank?
Good work.
Maybe I am not seeing it correctly or the installation was not finished yet but it looks like you do not have any protection (grommet, snap bushing or equivalent) for the cables going through your gearbox. If that's the case you may want to address that before having a dual smoke system on boardWe installed a 4 gallon aluminum tank flush with the baggage compartment, it is strong so can load anything on top of it. Pump and solenoid is mounted below it. The pumps runs both ways so it is filled from outside with a fill switch in the baggage compartment. Has a vent/ over flow near the fuel tank vent, very clean installation.
Ha ha, no you were seeing it correctly! The wiring was tidied up and grommets installed through all bulkheads before closing it upMaybe I am not seeing it correctly or the installation was not finished yet but it looks like you do not have any protection (grommet, snap bushing or equivalent) for the cables going through your gearbox. If that's the case you may want to address that before having a dual smoke system on board![]()
