100% of the 8's built are sliders .........if that helps you .
IIRC, all of Vans' company 6/7/9's have been tippers.
One other advantage of the tip-up is weight, it is lighter than the slider.
Well, that wouldn't be correct![]()
The slider's biggest disadvantages to me are:
- more complicated to build
- a bit heavier due to the extra frame between the front and back halves
- reduced visibility due to the extra frame mentioned above
- more difficult to seal (in my opinion)
- more expensive
The sliders do look nice, like a fighter jet.... but you'll notice that the newest jets all have tip ups now!
OTOH, I have a slider on the F1 Rocket and on the RV-6 in my shop. Sigh....
Recent fighter jets have tip ups - except they're hinged at the back and not the front. The F-35 isn't a real fighter jet, BTW
I'd quantify the visibility thing - tippers have better forward visibility, but much worse rearward visibility. Also, I don't think I've ever heard of a slider leaking onto avionics, so sealing would seem to favor the slider.
Most aircraft have "O" rear visibility. It's not an issue. But the things that can be hidden by that roll bar IS a big deal. I would never have a slider for that reason.
Sealing a tip has proven to be well within the capabilities of a kit builder....... If it leaks, it's because the builder did not seal it well enough.
Don't forget that the RV-3s, RV-4s and many Rockets hinge at the side.
11 years after the question was posed ... of the 269 RV6, 7 and 9s in the UK the % tippers is:Good Morning Gents!
Just curious if anyone knows today's ratio between Sliders & Tip ups? Considering the RV14 is only available in a Tip Up, Is there more demand for the Tip Up?
Thanks!
| 6 | 61% |
| 6A | 36% |
| 7 | 45% |
| 7A | 58% |
| 9 | 53% |
| 9A | 41% |
| All 6 | 54% |
| All 7 | 47% |
| All 9 | 44% |
| All TW | 52% |
| All A | 43% |
| All RV | 49% |
I turned 70 in March and I had a T10 to S1 fusion back surgery last August and have been able to get in and out of my tipper 7 ok. A bit more of a struggle than before but doable. I approach getting in and out a little different than I did as far as foot placement, etc. I agree a slider would probably be easier in that you don't have to bend over as far. Loading baggage hasn't been much worse than before the operation, except I can't twist as much or lift heavy objects of course. On the flip side, working on avionics troubleshooting and wiring on the tipper is easier than a slider whether you have a back condition or not, due to the glare shield lifting when you open the canopy. I had to get creative to inspect underneath the panel for my condition inspection last month, (used a mirror, light and even a borescope for parts of it that I wouldn't normally have had to), but that is likely no different than if I had a slider. Getting the baggage bulkhead out during the condition inspection is likely harder on the tip up. It wasn't fun even before surgery. I was able to inspect and lube the Heim joints but If I ever have to crawl back in the tail to do maintenance such as a A/P pitch servo replacement or magnetometer replacement I'm gonna have to have some friends help or pay somebody for sure. So, you win some and lose some...If you are old with a fragile back like me, putting my dog, a suitcase, tool bag ,etc in the luggage compartment of a tip up compared to a slider with super tracks, well it probably wouldn’t end well for me.![]()
…and 100% if 12s and 14s are tip-ups.Ratio
Don't bet your life on this.Just out of curiosity this moring while out flying I tested how much the slider rollbar would hide from your vision. My results were very eye opening (couldn't pass this pun up). I would pick small objects from up close to way out in the distance such as a house to do my testing. I would close one eye and position the object on one side of the roll bar and then I changed eyes while holding my head steady and found that I could see the same object with either eye without moving my head.
From my testing the rollbar does not blank out any objects as long as you have both eyes open. Note: I did do all of this testing while setting in the normal position and looking past all areas of veiw of the rollbar.
I know this won't change opinions on the purist who favor the tipup's, but no one can tell me that my slider rollbar is unsafe and hides objects while flying.
