www.instagram.com
When they put out that video i ordered one, going to be a long time before I need it!Evoke posted a couple videos, one specifically on a wire brush that they taped to hold the wires closely. Otherwise they were using a hand wire brush.
Evoke Aircraft Design on Instagram: "We had lots of questions recently over what kind of tooling we use to help sand down our rivets. Well, luckily, in this #QuestionOfTheWeek, Jonathan gives you all the answer you’ve been waiting for! #Aviation #Beh
14 likes, 0 comments - evokeaircraftdesign on March 12, 2026: "We had lots of questions recently over what kind of tooling we use to help sand down our rivets. Well, luckily, in this #QuestionOfTheWeek, Jonathan gives you all the answer you’ve been waiting for! #Aviation #BehindTheSchemes".www.instagram.com
I took your lead from that old thread and ordered the dispenser. Way easier. However I used Superfill which seems to be a bit softer than the epoxy that you used.I also filled all my mandrel holes and the scotchbrite wheel didn't hurt the filler, if anything it made them all smoother, look at the bottom of the thread for the post-paint photos.
Filling Pop Rivet Mandrel Holes Before Paint
This is how you take your build to the next level. If you don't have a pop-riveted kit you should probably click the back button now. If you've ever looked closely at a Sling TSi built by Midwest SkySports you will notice that they fill EVERY pop rivet mandrel hole before they paint the plane...vansairforce.net
