Unknown. Looks like the breakdown started at the one cam lobe and/or pair of lifters. There was hardly any corrosion found in the engine, just some very light corrosion on some of the cylinder walls.Is this caused by aerobatics or something else?![]()
Possibly.Sorry, you think if it had a spin on filter vs the pressure screen maybe less residual damage?
Hello Paul. It’s two lifters that shared the one cam lobe that were badly pitted. All other lifters and cam lobes looked very nice.Jerry - was it just that one lifter that went bad? If i interpret the pictures correctly, at least one of the lifters look pristine…
Thanks Brian. I’m just glad it didn’t self destruct while in the aerobatic box during a vertical dive at 1200’ AGL at 180 knots!Again sorry to see the damage, I guess it’s all replaceable, hopefully everything else checks out ok.
that would be a VERY good bet. As the torn off metal circulates, it scores the bearings and pump housing. As the metal falls of the lobe and lifters, it falls on the piston skirts, usually the two directly below the bad lobe/lifter.Unknown. Looks like the breakdown started at the one cam lobe and/or pair of lifters. There was hardly any corrosion found in the engine, just some very light corrosion on some of the cylinder walls.
Put the samples on a piece of paper, move the magnet UNDER the paper - not in contact with the sample. No surface tension or adhesion to worry about. Ferrous material will line up with the lines of magnetic flux and the aluminum or other low permeability metals will not.Only if the piece is large enough. Also, Due to the surface tension of the oil, alum particles will stick to a magnet. Very easy to get bad conclusions with magnets and small particles.
