I finally found the issue with my red cube! I have replaced it 3 times and after only a couple of hours, the readings became erratic. Turns out, there was a TINY scuff in the yellow data wire coming out of the EMS module mounted behind the panel. The wiring harness faces upwards towards the canopy hinge. While the canopy is open, it seems miles away from anything. I was in the process of preparing to rewire the cube and noticed a tiny scuff the size of a pin prick, in the yellow wire. I couldn't figure out how it got there then suddenly I noticed a tiny little black spot on the bottom of the canopy hinge. I pulled the canopy down and figured out that the yellow wire (Located towards the TOP of the wiring harness) BARELY touched the canopy hinge in the closed position. I taped the wire, installed a nylon conduit over the harness for protection and zip tied the wiring harness away from the canopy hinge. NO MORE ERRATIC READINGS! Prior to my discovery, I had relocated the cube away from the exhaust pipes and behind the rear baffles to minimize heat. I also left it suspended, not mounted to the engine block. I definitely recommend suspending the cube vs. mounting on the block, although I don't believe that was an issue. Mine worked perfectly, suspended between the cylinders and exhaust pipes for 150 hours. Turns out, that's how long it took for the wiring harness to chafe through up against the canopy hinge. Just glad to have found the problem after 3 expensive replacements.
