Looking for suggestions on resolving an issue with constructing the rollbar. In my case the width of the bar does not match the width of the support section that hold the base of the bar.
To be clear see the pictures below:
The distance between the blocks is a bit to wide for the bar. I understand that the bar halves are formed as T0, and then hardened via heat treating, and that can cause some deforming. At least that is what tech support indicated. They went on to say that some massaging may be required. I'm thinking about removing the support blocks (currently bolted in place) and elongating the bolt holes to allow the bloc to shift inward about 1/8in on each side. Thinking about the forces involved during a rollover, the bulk of the force will be inward (crushing) on the top of the rollbar, and that would cause the ends to want to push outward, so elongating the holes as proposed, should not impact the bolts shear force support of the block.
What have others done in this scenario?
