MOSAIC LSRI course completed
I’m not sure that this will help, because there are people in this thread that don’t seem to want to hear what others are telling them but I will give it one more shot.
The process is standardized to where every single applicant should get the exact same operating limitations with the exception of the description of a phase one flight test area, and whether they are requesting approval of night and/or IFR operations.
It is not possible for an applicant to request specific limitations that they would like to have, with the exception of whether they will be approved for night operations and or IFR operations. All the rest of the limitations get issued if they are specified in the order for that particular category Aircraft.
An FAA ASI or DAR cannot pick and choose what operating limitations they issue for a given certification. Appendix D in 8130.2L has descriptors on each limitation in the list that specify what Aircraft it has to be issued for.
The problem that arises is it does require a bit of knowledge about the different certification categories in order to make a determination of whether a specific limitation applies to a specific Aircraft.
So in simple terms, when someone does receive a certificate with a difference in their operating limitations, it means the issuer made a mistake. Not that the issuer chose to issue differently for that specific applicant.
The reason many FAA offices suggest the use of a DAR, is because of their familiarity with the processes. A lot of DAR’s do numerous certifications per month, while many FAA ASI’s may do only one or two per year, if any at all.
So, in a nutshell, the only luck of the draw is whether you end up working with someone that is familiar with the process and can do it without any mistakes, which even all of us that do this on a regular basis still do occasionally.
As for issuing operating limitations specific to Mosaic, that is not yet relevant. When 8130.2M is released, it will have updates that are specific to new mosaic rules. Those rules don’t go into effect until July 1, so .2M will likely be released sometime shortly before that date.
The only change that was in release .2L that had any significant relevance to the new mosaic rules was updating the operating limitation that specified the level of certification required for completing a condition inspection (LIMITATION # 18).
Would someone that received their NEW OP"s limits from a trusted FSDO, list the numbers from 8130.2L appendix D, that was applied so others can make sure that when they are going over the restrictions with the FAA, that you can catch an error early.
Or maybe post their entire limits, excluding personal information.
https://www.faa.gov/documentLibrary/media/Order/Order_8130.2L.pdf starts on page 177 / 231.
For the benefit of the community I took a couple of minutes and went through the Appendix.
For an experimental amateur built certificate for an aircraft with an internal combustion engine of less than 800 hp, you should be issued the following. (Experimental Light sport is slightly different. I noted those changes below.)
For future.... Keep in mind this is only valid for limitations issued under 8130.2L.It will likely be different for future releases.
Numbers
1
2
3
4
5
7 (there are 3, make sure it reads "The pilot must hold AIRPLANE category and SINGLE ENGINE LAND class....")
11
13
14
15
should read as below VVV
No person may operate this aircraft unless within the
preceding 12 calendar months it has had a condition
inspection performed per the scope and detail of Part 43,
appendix D, manufacturer or other FAA-approved programs,
and was found to be in a condition for safe operation.
The inspections must be recorded in the aircraft
maintenance records showing the following, or a similarly
worded, statement: “I certify that this aircraft has been
inspected on [insert date] per the [insert either: scope and
detail of Part 43, appendix D; or manufacturer’s inspection
procedures] and was found to be in a condition for safe
operation.”
The entry will include the aircraft’s total time-in-service
(cycles if appropriate), and the name, signature, certificate
number, and type of certificate held by the person
performing the inspection. (15)
18 (Not issued for E-LSA)
20
21
22
25
36
38 (Not issued for E-LSA)
39
41
42
43
44
45
46 (only issued if night authorization was requested)
47 (only issued if IFR authorization was requested)
48
49
53 (There are 2, make sure it reads VVV)
Flight over a densely populated area or in a congested
airway is authorized for the purpose of takeoff or landing;
or unless sufficient altitude is maintained to make a safe
emergency landing in the event of a power unit failure,
without hazard to persons or property on the ground. (53)
In addition to those listed above, E-LSA would also be issued 12, 13, 17, and 26
This is the most valuable post in the past 7 pages...... Thanks Scott
Scott. You are the man. The only question I have is the Sentence in 8130.2L #7. . "Except during Phase I flight testing, holders of a student pilot certificate with a flight instructor endorsement for solo flight may operate the aircraft in solo flight without holding a category or class rating or other Part 61 endorsements only for the purpose of meeting aeronautical experience requirements of Part 61 pursuant to a sport pilot, recreational pilot, or private pilot certificate." Thanks again.
This was added with the release of 8130.2K.
It is a nice concession that the FAA made, that allows a student pilot to fly solo in an experimental amateur built that they have been taking flight training in.
The reason being, is that they don’t have a category and class certificate when operating with a student pilot certificate, so they don’t meet the requirement as the limitation was originally written.
The FAA felt that it wouldn’t be appropriate for a student pilot to be flying an aircraft that was still operating in its phase one flight test period, so that restriction was included in the limitation, which I tend to agree with, and I think most people would.
After Talking to my FSDO he made me realize that your Phase 1 testing location may not default to the one you want after your OL update request. I was under the impression that my local county airport would be available, he said that was not the case.
Correct
Approval of the Phase 1 test area is at the judgement and discretion of the person issuing the certificate, and has to be selected in order to assure compliance with FAR 91.305
91.305 Flight test areas.
No person may flight test an aircraft except over open water, or sparsely populated areas, having light air traffic.
Previous versions of Order 8130.2 issued a limitation # 22 that just stated that the local FSDO needed to be contacted after incorporating a major change, and concurrence received in writing that they agreed with your proposed flight test area (at least one or two earlier versions didn't even require them to be contacted). So for anyone still operating with these limitations, the originally issued Phase 1 flight test area is not relevant.
The wording of limitation # 22 since .2K was released is -
After incorporating a major change per § 21.93 that was not
presented to the FAA when this airworthiness certificate was
issued, the following applies:
Notification of Major Changes. The responsible Flight
Standards Office where the aircraft is based must be notified
and its response received in writing before flying this aircraft.
This notice enables the FAA to determine if operating
limitations require amendment to reduce exposure of the
public to risk due to the major change.
Operations. Comply with § 91.319(b) using Phase I operating
limitations.
Registry. If the major change includes installing a different
model of engine or a change of a fixed pitch from or to a
controllable propeller, the aircraft owner must submit a
revised FAA Form 8130-6 to update the aircraft’s file in the
FAA Aircraft Registration Branch, AFB-710. (22)
Since limitation 22 now contains -
limitations.
I interpret that to mean that the test area described in the operating limitations is once again relevant for any Phase 1 testing done post initial phase 1 flight testing, so if you are submitting an application for amended operating limitations, the program letter you submit should state what you are requesting as a Phase 1 flight test area, and what airports you would like operations to be authorized at within that test area (this is giving the issuer the opportunity to evaluate whether the requested airports can be utilized while still meeting the requirement of FAR 91.305). There is no guaranty that you request will be 100% approved, but it is a starting point. Be aware that the days of using any airport within the boundaries of your Phase 1 test area are over. All authorized airports get listed in the operating limitation that define the test area, and in my region anyway, the applicant is expected to provide justification for the need/use of each airport being requested.
Side note - Your program letter should also mention whether you want authorization for Night and/or IFR to assure that the specific limitations for these operations get issued.
I just got my amended Operating Limitations yesterday. There were a few discrepancies, but I called the guy at the FSDO who’d done the work. After some discussion and a few more emails back and forth, I have the final version, and everything’s correct.
It was fortunate that when I called, my project wasn’t yet “closed out” in the AWC Portal. So he could just open it and make edits. If it’d been closed out, it would have been a whole new submission to get things corrected.
I will say that being quite familiar with 8130.2L Appendix D helped when I was talking to him. And I’d submitted a draft of the expected Ops Limits, so I knew what I was looking for.
Overall, a pretty positive experience. I think it took 4-5 weeks from my submission on AWC to the final email with the completed Special Airworthiness Certificate and Ops Limits.
... Be aware that the days of using any airport within the boundaries of your Phase 1 test area are over. ...
Thanks for pointing this out. I vaguely noticed that in the new OpLims for my RV-3B that in Phase I I'm only allowed operations from my local (grass field) airport. I did find that a bit odd but not really important for putting airplane back in Phase I to add loops to approved maneuvers. Yet nearest paved runway (KCTY) is 15 miles away and within specified 30 miles radius Phase I test area. Would have been important for testing wheel shimmy on my RV-4.
Anyway, definitely important for others to notice.
Finn
Finn
Due to MANY protests from both DARs and applicants, this "one airport" rule lasted only a few days. You may have several airports available to use, but each has to be listed in your op lims.
Mel is of course correct.
I didn't mean to imply that only one was available.
The order (once the corrections were made to .2K) allows for more than one. The position taken by our local FAA authority here in the northwest is that the applicant should give justifiable reason for each additional airport requested in their program letter.
A few common ones are - availability of fuel (in case none is available at home base), access to a close by cross wind runway, access to a repair station that can complete a xponder certification, etc.
Good to see you back on the forums Mel (y)
I listed almost every airport (February of 2025) in my Phase 1 and initially the DAR said "we'll see" but FSDO approved it. I also got a little push-back on my request for a 100-mile radius but after I saw on the forum a member received a 100-mile radius requested the AWC from the FAA (I think it was less than 5 bucks to get a copy) and after showing it to the DAR became no issue. (Vic was the DAR on that one)
My brother is looking for the nearest LSRI course near San Diego, (LA would also be ok) Anyone know of a course being taught in Southern Cali.?
Good to be back. After over 2 months of hospital and rehab.....Getting old is NOT for wimps!
It's going to be a while before I can get back out in the field, but I am doing amended Op Lims from home.
Right now, it's Buckley Washington....
But Reedley College in CA is gearing up to offer.... check with them.
559-494-3000 ext. 3243
congrats on finishing the course tbh. sitting through those intensive classroom hours is exhausting but being legally allowed to sign off on your own annuals makes it totally worth the grind. definitely takes a huge chunk out of ownership costs.
This coming weekend is my class at Rainbow - once I get the cert, can someone give me a a clear step-by-step with the form numbers, what to enter on them, and how to get cleared to do my own conditions/annuals? Thanks!
Rainbow will do the full submittal to the FAA, so you get a cool little green plastic card with Overall and Wilbur saying Repairman in the mail.
To get approved to work on an LSA or EAB you own requires the "newer" Operating Limitations. If not you need to go to the FSDO and have it revised. If your Op Limits are OK and you have a repairman I think you are good to go...
However if you are new to condition inspections, GET HELP from a knowledgeable person and be willing to PAY THEM... Best to get a person who has built, owned, operated this make and model. A&P who know your make and model is OK. They may be willing to supervise, direct and assist you.
Do NOT forget service bulletins and safety directives. They may not be mandatory but you need to read, check and document them, even if you don't comply. No Bash of Rainbow but it is NOT a comprehensive course or get into details about your aircraft, engine, prop. I helped a RV-12iS builder with his second condition inspection. His log books and 1st solo condition inspection he did a year earlier left a lot to be desired. He went to Rainbow and surprised how little he knew or understood or remembered.
The good news is 6 mo ago there were issues with LSRI and EAB condition inspections (this is all new with MOSAIC), but now it is worked out. Scott MacLean, very nice guy, bought a Cozy MkIV he did not build, has a YouTube Channel.
Once again, there is NO certification requirement to be authorized to work on (or repair, re-build, re-paint, restore, modify, etc.) an Experimental LSA or Experimental Amateur Built aircraft.
The Repairman Certificate is to provide authorization for signing off the Condition Inspection only.
The rainbow 15 day class got well enough into the weeds to get most of the stuff figured out.
They even offered to use student aircraft as examples. I'd encourage conscientious owners to fly there and volunteer. Just check out the runway first, might not be long enough for some pilots, interesting hill in the middle. I've got 4 videos including one cockpit view.
The one owner that flew in many days was bashful regarding the scrutiny but later got some nice stuff figured out while helping others learn.
When did they start doing this?... Rainbow did not offer this 4 months ago.
Did you take the Rainbow course?
I took the class in Feb and they did not do this at that point.
Rainbow did not offer to submit any paperwork to the FAA as of the last weekend in March, nor would I expect them to.
Jackking123 has repeatedly posted inaccurate information, as shown below.
