Just wondering how many RV-14's flying have had additional rudder trim added after the build.
In cruise my yaw damper (14A) offsets the 1/4 ball needed, climb just lean slightly on my right pedal till I get to cruise. Seems some trim tabs are adding a lot of drag when the majority of the time very little needed. 10 about the same.Just wondering how many RV-14's flying have had additional rudder trim added after the build.
@dmattmul , I'm not off a 1/4 ball, but what yaw damper settings did you end up with?In cruise my yaw damper (14A) offsets the 1/4 ball needed, climb just lean slightly on my right pedal till I get to cruise. Seems some trim tabs are adding a lot of drag when the majority of the time very little needed. 10 about the same.
Max Torque = 100%@dmattmul , I'm not off a 1/4 ball, but what yaw damper settings did you end up with?
@dmattmul agree with Walt here -- the GSA28 is going to be "driving" constantly, would be better to shim the rudder trailing edge -or- adjust the gear leg fairings -or- go nuts and build in a servo controlled rudder trim on the trailing edge - tie that to the yaw-GSA 28 and let the G3X resolve the displacement via the trim tab motor, not the rudder servo...Trim tab should be used to center ball at cruise. YD is not meant to correct trim routinely.
Let me gather data before permanently adding drag to my airframe. How much offset I needed in cruise was depended on cruise speed but need to review.@dmattmul agree with Walt here -- the GSA28 is going to be "driving" constantly, would be better to shim the rudder trailing edge -or- adjust the gear leg fairings -or- go nuts and build in a servo controlled rudder trim on the trailing edge - tie that to the yaw-GSA 28 and let the G3X resolve the displacement...
It’s all “drag” of some stipe - displacing the rudder by pulling/pushing on the cables, or by displacing the rudder by trailing edge devices (wedges, shims, tabs).Let me gather data before permanently adding drag to my airframe. How much offset I needed in cruise was depended on cruise speed but need to review.
YD torque (%) in cruise varied from ~+6% to ~-8% depending in cruise while pitch torque (%) with auto-trim varied from ~+7% to ~-10% at lower cruise speeds to slightly increased % torque values at higher cruise speeds. Roll torque (%) was statically greater as I do not have auto-trim on that axis. What would be considered an excessive amount of torque%? For now, I'll continue to monitor the data.
My comment about YD could offset the ball 1/4 of a ball was meant that it has capability to do so, it's actually greater but I'll continue to review.![]()
Richard, it's a 14A. at 140 to 150 KTAS there was no change when we added the wheel pants ball about 1/2 outA full ball at cruise is a lot.
Is it a 14 or a 14A?
There’s no TE radiuses to mess up and no incidence or alignment issues unless there’s some gross wing twist introduced during building. Every one I’ve seen the rear spar clecos into the spar carry thru first time. (Which is amazing as a side note)
So if you’re content the control surface rigging is good then that only leaves the gear leg fairings or the wheel pants.
If it’s an A then it could also be breakout force/nose wheel prop slip stream interaction (but that’s unlikely a full ball at cruise speed - it’s usually transient and you can tell by yawing the plane)
I would closely look gear leg fairing alignments before making any kind of adjustments to the airframe.
Maybe take all the gear leg and wheel fairings off and go fly as a first step. If you still have a 1/2 or 3/4 ball out then you can rule out the fairings, but then we back to first base which is rigging and airframe alignment![]()
That’s a big change. I think something must be moving, and the only thing that comes to mind is the nose wheel. If possible repeat the experiment, have an observer with binoculars look at the nose wheel.in my case, gear fairings did not change my ball out to the right at 140 KTA (1/2 ball out) but accelerate to 170 KTA made centering the ball (ball fully out to the right) a great effort, and locking my leg straight was only a short-term solution.
That trim tab is great. I like how it takes advantage of the existing holes for the tail light. Is it aluminum, and how thick material did you use? I'm thinking about 3D printing a few candidate designs to get the shape and size/drag right.Here's my RV14A rudder trim tab that mitigates the half ball width of uncoordination otherwise. View attachment 114789
Hard to tell with the photo, but it appears that the tab slightly obscures the tail nav/ strobe on the port side. Is there any location - aft, port side - where you cannot see either the port side nav or the aft nav light? Same question for the strobes.Here's my RV14A rudder trim tab that mitigates the half ball width of uncoordination otherwise. View attachment 114789
Just keep in mind any permanent wedge or other permanent mods might add drag to one side when you really don't need drag, (IE reduced TAS) at that pitch attitude.That trim tab is great. I like how it takes advantage of the existing holes for the tail light. Is it aluminum, and how thick material did you use? I'm thinking about 3D printing a few candidate designs to get the shape and size/drag right.
I think it was ~30° -- no math, just a whole bunch of TLAR, then a test flight...For the RV'ers that are using this rudder trim tab... Just how much of an angle are you putting on the bend?
