I do have an inquiry with Dynon technical support, but figured a smart person here on VAF might be bale to help.
I receive an 'Autopilot Pitch Disconnect' message every so often in my Vans RV-9A. This behavior existed previously, and appears to be continuing, despite installing a newly overhauled and upgraded (SV-32 to SV-42) pitch servo. I also sent the SV-AP-PANEL back to Dynon per SB-00090, so its unlikely to be that. Any ideas what may be causing this? The AP status on the Dynon display appears to be engaged the entire time. It also appears that the roll is disconnected at the same time in the log file, but this audio message is 'overwritten' by the newer pitch disconnect message?
I can post full alert data logs, but a snippet of the event is below:
All this takes place in under 1s, so no real impact to the control of the aircraft. It does appear to happen more in turbulence. Some thoughts:
1) Maybe a failing disconnect switch? Wouldn't explain the immediate re-connect.
2) I did check as much of the wiring as I could during the CI, no obvious issue with the servo wiring or disconnect wiring. I didn't check the wiring inside the control stick.
3) Maybe a gain setting is cranked up too high and the AP gets confused?
| AUDIO | STOP | AP_DISC |
| AUDIO | STOP | AP_ROLL_DISC |
| AUDIO | STOP | AP_PITCH_DISC |
| AUDIO | PLAY | AP_CONN |
