Thanks, that is a good thread. So here is what I found so far: NOTE: I haven't verified actual use yet. When the parts come I'll report back, however I think this is correct:
https://vansairforce.net/threads/e-mag-spark-plug-wires.206686/
- NAPA Beldin p/n 700108
https://www.napaonline.com/en/search?text=BEL700108&referer=v2
Note: Probably need to buy 2 kits because the 17" wire may be to short?; not sure on this.
- MSD Spark Plug Wire Terminal - HEI Style Terminal - Dual Crimp - Set of 50
SKU: MSD34604
https://pitstopusa.com/products/msd-spark-plug-wire-terminal-hei-style-terminal-dual-crimp-set-of-50
OR
Make the connection with spark plug wire boots, terminal kits, and more when you shop at Summit Racing Equipment!
www.summitracing.com
Same part and same price so they probably come out of the same warehouse bin!
I think the key is you need to search for HEI 6.5mm terminals.
The ETCO: ETCO DT-1000-HB terminal looks like the correct part however you have to buy a spool of 2500 from ETCO... Not finding anyone who sells. I think the MSD 34604 is a rebranding of the ETCO DT-1000-HB
Here is the AI explanation:
When selecting terminal kits, consider the terminal type—common options include male HEI (High Energy Ignition) and female socket styles. For HEI-style terminals, kits like those from MSD Ignition are available and feature spark plug-style terminals designed to prevent vibration loosening. These kits are compatible with various distributor types, including Ford and GM models.
For custom installations, universal kits with crimping tools and terminals are available. The MSD Pro Crimp Tool and Pertronix Spark Plug Wire Stripping Tool are recommended for precise installation.
These tools allow for the creation of custom spark plug wires with proper crimping and insulation stripping.
While specific 6.5mm terminal kits may not be widely advertised, many universal kits support a range of wire diameters, including 6.5mm to 8.5mm.
Brands such as Taylor Cable, MSD Ignition, and Accel offer spark plug wire sets with various terminal configurations, including HEI and socket styles, which can be adapted for use with 6.5mm distributor caps.
In summary, while dedicated 6.5mm terminal kits may be limited, compatible solutions exist through universal kits and custom wire builds using appropriate crimping tools and terminal types.
