Like many of you, I'm following the transition to unleaded Avgas with interest. I've found some lively discussion around the internet but very little here on VAF. I find that odd so I thought I'd start a new thread here.
Just to get some discussion going, the unleaded fuels currently being considered have shown some potential drawbacks - both real and perceived. Here are my concerns in order:
1- Fuel tank sealant compatibility
As stressful as it was to build my fuel tanks, if there is even a 1% chance that a candidate fuel will cause tank sealant to fail resulting in fuel tanks leaks, I won't use it. Instead, I'd probably sell my airplane and buy something with fuel bladders or something that isn't damaged by the fuel. No way I'm removing the tanks, removing the existing sealant and re-applying something else.
2- Paint damage
Paint damage caused by spilled/leaking fuel is almost as serious a concern to me. I will be paying a good chunk of change to get my airplane painted next year and if a new unleaded fuel ruins my paint job, I will not be a happy camper.
3- Engine timing changes
Any changes that might be required to ignition timing don't concern me too much. I think we have some leeway as experimental builders to adjust timing. I know that will reduce performance but I'm naively thinking I'll have some "overhead" to work with (215HP). I know the certified folks are saying this is a deal breaker.
4- O-ring deterioration
O-rings - little concern. Swapping o-rings doesn't seem like a big deal but again, I'm naive on this one as well.
5- Miscibility (mixing fuels)
This could be a problem initially but I'm not worried about it. During the transition, I'll just avoid mixing fuels if that ends up being an issue. Inconvenient? Yeah. Deal breaker? Not for me.
2- Paint damage
