Yes. We pushed the bolt in from the top until just a few threads stuck out the bottom. I stuck the two washers over those threads with a glob of grease, then we held the nut against those threads with a 12" hemostat while using a gear wrench to turn the bolt head. After the threads were engaged with the nut, we switched the hemostat for a wrench on the nut and tightened, thus drawing the bolt in the rest of the way until flush and the nut was tight. The bolt was longer than a 20, so the dent we pounded in the firewall was necessary. The close-tolerance bolt was long enough that it allowed the shoulder of the bolt to bear completely on both holes in the strut socket no more than the thickness of the two washers. The project got a workout today with a 60-kid Young Eagles event. Re-checking for wobble afterward was gratifying.I installed a -21 from the top (for reasons that I mentioned earlier in this thread) with a washer under the head, and two under the nut, and I did not pound out the firewall.
You just add the washer and the nut as you are tapping the bolt through the leg. IOW... you can't just drive the bolt in and expect the washer and nut to go on without interference from the FW.
To remove the existing bolt from the top, I clamped vise grips onto the head and tapped the grips with a hammer.
