This is really something to think about…. And not just in the sense of resale value, but in terms of your own 9and your passengers) safety.
Let’s look at a different example that I use all the time when talking about flight testing. As far as the regulations are concerned, you can legally get out of your C-150 after your (passed) private pilot check ride, and get right in a fixed-gear fast-glass airplane with a 199 HP motor and do its first flight, with 40.1 hours in your logbook. Does that sound like a good idea to you? I think most folks would be “uhhh….let’s think that through again…”
If you BUILT an airplane, you have probably spent several thousand quality hours with it and know every nut, bolt and washer. If you are an A&P, you have the equivalent of 3,000 hours of training and practice. If you are inspecting a certified airplane, you have the A&P time plus three (or is it five…I forget) years of demonstrated experience as an A&P plus additional training and testing. Let’s stack that up against a 16 hour, two-day course…..Hmmmmm….
If you have built previous airplanes and decided to buy one from your buddy, you have all that building experience and have done inspections before, so I think there is a pretty reasonable use of the new authority to inspect an airplane that you bought.
I am ALL for more freedom to do what we want in the experimental world, but I do pause when we realize that in the case of anything bigger than a single-seater, we are putting potentially unsuspecting passengers at risk…. So let’s use the new authority (and responsibility) wisely!
