glider_rider
I’m thinking of adding a dedicated circuit to power the Starlink mini antenna on my RV10. I’d like to bolt it to the top of the baggage compartment.
I’m a bit confused about grounding the Starlink. Would it be OK to ground it locally in the back or should I run a ground wire to the front of the aircraft? What do you think?
