Hi all,
I'd appreciate your thoughts on the following situation.
My airplane has dual battery & dual alternator setup. The problem is that the batteries sketch me out (they are some sort of motorcycle batteries without BMS). The current power architecture is like this:
I'd like to replace the batteries with EarthX. The problem is that I don't really have enough space to install two ETX-900s. Then again, I'm not sure if I need two? What if I just remove everything in the red area and install a single ETX-900? I usually operate with Bus Tie turned on anyway (it's easier operationally, because the backup alternator doesn't charge the battery on the ground). What would be the downsides of this? This is what it would look like:
Of course this removes the redundancy of having a second battery, but do they really fail in flight? Would appreciate your thoughts on this.
The plane is glass (G3X + G5). I do fly a certain amount of IFR. It's usually not very hardcode, but losing the radios in case of an electrical failure would definitely suck.
Thanks!
Thanks!
