When I set the breakout force on my nose wheel, the nut is a little too far past the pre-drilled cotter pin hole for comfort. I've searched high and low for a washer that will work to take up the extra space, but anything that has a large enough ID is much thicker than I need. McMaster does have 1/16" thrust bearings in sizes that would work. I know nothing about the properties of these - they are either listed as "oil-embedded" or "dry-running " bearings. Is there any reason one of these wouldn't work for this application? Or any other ideas of what I can search on to find something that would fit the 1 1/4" gear and be about 1/16" thick?
https://www.mcmaster.com/products/b...-type~thrust/thickness~1-16/thickness~0-0625/
