mhabib2011
I'm New Here
Hi All,
My landing gear & mount holes are elongated, all 3 of them. All drilled with new tooling. First one drilled with a cobalt drill bit, second one with a cobalt reamer and the third one with a cobalt reamer with carbide bits.
I had a call with Vans, and it seems like the issue is my mount and landing gear came undersized. Based on the phone call, I should only need to drill the back hole in the mount, instead my kit came undersized, and by drilling manually the long holes (mount front hole, landing gear, than mount back hole), the holes end up elongated, no matter how good the drill bit is, as the hand is bound to shake throughout the drilling.
To fix this issue, I was given the suggestion to use an "X" or "Y" bolt. As I can not go beyond that in size, I only have one chance to fix this without needing to buy all new hardware. So, I would like to check on the plan before I proceed. Also I have some open:
- I intend to disassemble the landing gear from the mount and drill the landing gear using a V bolk and drill press first with a slightly undersized cobalt drill bit, then with a cobalt reamer.
- I still do not see how I could drill the front hole in the mount precisely. I considered removing it to drill it with a drill press, but it is so bulky. Hand drilling is obviously not a good idea to get a precision hole. Any suggestions on how to drill the front mount hole precisely?
- Once I have the front mount hole and the landing gear drilled, I will assemble all in the aircraft and clamp everything, to drill the back hole of the mount, first with the slightly undersized colt drill bit, then with the cobalt reamer.
- Where can I buy "X" or "Y" bolts? I do not see relevant results in google with this naming. The suggested company "genuine aircraft hardware" is not responding to email.
- I still have the open question of the small edge distance the mount came with from Vans. After drilling it became less: 0.17inch. After drilling to the next "X" or "Y" bolt size, it will become less. What is the minimum edge distance for the landing gear mount? Attached is a picture of what I am referring to.
