Spark plug gasket orientation?
Desert Rat
A buddy asked me today if it mattered which way he oriented the spark plug gaskets. I was like, well yeah, the inner diameter has a sharp edge on one side and and a radius on the other. The radius goes next to the plug...right? Perhaps I'd better look that up.
Now here we are hours later and darned if I can find a reference for that anywhere other than a 35 year old memory from A&P school. I looked in both the Champion and Lycoming manuals. Both make reference to all the other stuff we all know; throw a plug away if you drop it and use a new gasket every time (yeah, I know annealing gets you a do-over), but I can't find any reference at all to there being a proper way to orient the gasket.
Can anyone point me in the right direction for an actual written instruction that makes mention of this?
In general rounded goes on the permanent surface (in this case the engine side), to prevent marring. The latest Piper ADs on wing nuts/bolts specify this. I don’t have any specific written instructions for spark plugs though.
Rounded goes on the permanent surface (in this case the engine side), to prevent marring. The latest Piper ADs on wing nuts/bolts specify this. I don’t have any specific written instructions for spark plugs though.
I seriously doubt an annealed copper washer is going to mar anything but that’s interesting.
I’ll keep that in mind.
I have always put the flat side against the cylinder. Don’t know why either…..
I doubt it matters as both sides surface area are pretty much the same and all we are trying to do here, beside the obvious of prevent leaks, is to transfer heat to the plug.
AOPA article from Savvy says: When reinstalling plugs, remove and discard the used copper gaskets and install new ones, with the flat side facing the spark plug flange.
FWIW and not that it means anything, I asked chatGPT, MS Copilot and Grok and all three said the rounded side goes toward the spark plug. Geez, its almost like talking about primers.
chatGPT:
Copper aviation spark plug gaskets are often designed with one side rounded to create a more efficient seal when the spark plug is installed into the engine. The rounded side typically faces the spark plug shell, and the flat side is compressed against the cylinder head when the spark plug is torqued down.
This design helps to create a proper seal by accommodating the slight variations in surface roughness between the spark plug and the cylinder head. The copper material itself is also excellent for heat conduction, helping to dissipate heat from the spark plug to the engine, which is particularly important in aviation engines that often operate under higher stress and temperature conditions.
In summary, the rounded side helps to ensure the gasket conforms to the spark plug and engine head, aiding in a tight, leak-free seal while providing thermal conductivity and durability.
Grok:
Copper aviation spark plug gaskets are rounded on one side to ensure proper sealing and heat transfer in aircraft engines. The rounded (or beveled) edge is designed to face the spark plug, while the flat side faces the cylinder head. This shape allows the gasket to conform tightly to the spark plug's surface when torqued, creating a reliable seal that prevents combustion gases from escaping and maintains pressure in the combustion chamber.
The copper material is soft and malleable, so the rounded edge helps it deform and seat effectively under pressure, compensating for any minor irregularities in the mating surfaces. Additionally, the design aids in efficient heat dissipation from the spark plug to the cylinder head, which is critical in aviation engines that operate under high temperatures and demanding conditions. This combination of sealing and thermal conductivity helps ensure the engine runs smoothly and safely.
MS Copilot:
Aviation spark plug gaskets are rounded on one side to ensure a proper seal between the spark plug and the engine cylinder head. The rounded side conforms to the shape of the spark plug's shoulder, which is not a perfect 90-degree angle. This design helps the gasket create a tight, leak-proof seal when compressed during installation, preventing gas or pressure leaks that could affect engine performance. It's a clever bit of engineering to ensure reliability in high-stakes aviation environments!
I'll throw a "plug" in the conversation.
Which way should the copper gaskets be installed when using an adapter for auto plugs?
chatGPT:
Grok:
MS Copilot:
So much for AI ... They have a round edge side and a sharp edge side (just like all other flat washers), and that is because of the stamping process in making them from flat sheet material.
As to their orientation when installing them ...
HFS
FWIW...I had a mechanic (A&P/IA) tell me his rule of thumb if there isn't guidance is put the sharpest edge on the cheapest surface.
Well the real thing is to actually PUT a gasket in place.
Probably the reason auto plug gaskets not removable. Prevents dumb mistakes. I've seen them.
I don't think your engine could care less one way or the other. Just make sure you put one in. Oh ya make it a new one also.
My luck varies FIXIT
