litgourley22
Non-builder and RV-7 owner here looking for some help.
We found some chafing in the rigid brake lines where they had come in contact with the fiberglass and each base of the gear leg. And so, I had to remove the fairings to remove the brake lines. My original gear leg fairings were affixed to the gear legs with window seal foam and no clamps at all. Bad for all sorts of reasons, to include moisture. Aside from stripping (it’s powdercoat, so not going well) and painting the gear legs (because the powdercoat has failed and you guessed it, corrosion) before I install some pre-made brake lines I’m trying to figure out the final step of installing new gear leg fairings.
You might ask: “Why don’t you just install the old fairings?” Well, I’m not sure it’s possible to remove all the old foam and epoxy from inside the fairing to then get a good fit again on the gear leg.
So that leads me to two options:
1) buy the kit from Van’s and re-install them the correct way I’ve seen on the plans and within this forum and spend a ton of time AND/OR
2) Get the airplane flyable and fly it to one of you experts to help me or do it for me and save some time but spend some more money
I’m a fairly busy Air Force guy working full-time with some trips coming up soon and am curious how much of a process this is before I dive in. I’m not against doing this project on my own but cutting, fitting, priming and painting these things after an already long CI seems somewhat unfeasible for me right now.
If any of you have some insight or are willing to help close to the state of Virginia, I’d love to hear your thoughts and insights.
Ryan
Ryan
