Pirep...replacing standard green cables with ACS 1550 cables, threaded ends on the sheaths, no knobs, for an RV-8 quadrant. The key point? ACS cables are not a direct replacement.
Neither Aircraft Spruce or ACS publishes complete dimensions for the 1550 cables, only travel at 3.37". The only custom cable ordering dimension is overall length.
I ordered a set. Turns out the length of the swivel tube is 3-11/16", as compared to 2-11/16" for a green Vans cable. That puts the threaded tip a whole inch from where it needs to be. Or put another way, the support point for the sheath would need to be moved an inch further away from the connected device.
I have a call in to ACS to see if they make a 1550 with a 2-11/16" swivel tube, but at the moment I'm assuming no. So what to do?
Obviously I can make new brackets for the servo end, and move the sheath mounts at the quadrant. Plan B is shortening the threaded ends 1". Cutting and re-threading is easier than new mounting points. The green Vans cable measures as 2.25" travel, so lopping an inch off a 3.37" travel should work. Anyone done it?
Terrible sales drawing. The swivel tube looks short, but it's no
