... Think blind pop rivet - can be "set" with access to one side only. Once in a while you have the need to install an ADEL clamp where there is no access on the bottom mounting flange to "wrench" on a nut. Such as the case for these shown below - they go on pushrod tubes (between cylinders) for the mounting plate for my flow divider ("spider") on the engine for my Rocket.
What to do - silver braze a 10-32 hi temp nut to the bottom flange.
HFS
HFS
