Oil leak on 2 bolts on top #1
dbaflyer
Friend
Each of my cylinders has 2 bolts on the top of the case. The 2 by #1 cylinder appear to be leaking oil. The one in this photo has a pool of oil on top of it. Not sure what these bolts do but can they leak?
Your case seal looks to be leaking if it is in fact coming from the top. There are oil ports near the front middle and back of the case in these locations to oil the camshaft. High pressure oil is in those areas, yes it is possible. If it doesn’t leak much and is more of a seeping leak, then it’s not really an issue. If it’s a large leak then it’s something you should look into to as it may get worse.
Actually now I see oil on the cap screws you are asking about, I don’t have those on my engine so idk.
To track down where oil is coming from, you can use a black light in a dark hangar, I know Phillips X/C and Victory blends glow by black light. Then you can be sure it’s coming from that spot. I was thinking the case seam.
Those are probably fittings for roller cam. The leak is likely from the case split. Get rid of the adel clamp, install new lock washer and retorque that bolt. Check torque on the other two bolts. If it still leaks clean off the paint and coat the slit with a bit of fuel tank sealer.
thanks for the info. Will look at the case again. I know oil flows in mysterious ways under the cowl but it seems really odd for oil to have pooled on top of that bolt without having major oil around the base of the nut
The two bolts that are safety wired together are used to keep the roller cam followers aligned so that the follower does not rotate off axis.
Yeah I wouldn’t attempt to remove and reseal those without talking to someone more familiar with the roller lifters and how they are retained..
It was definitely leaking around the top through bolt with the clamp on it. The roller lifter bolts are fine
It appears I also have some leaking around the lower #1 head bolts. Is this something that can also be sealed somehow?
Clean it up. New lock washers and retorque bolt/nut. Remember to add the inch pounds needed to turn the nut after it's starting to engage the lock washer. Then do the pro-seal cover over the split in the case. I use a curved tipped syringes to apply the pro-seal down into tight places and not make mess. There is silk threading that seals the two case halves and if those bolts were taken off to install clamps and not re-torqued correctly, it can weep oil over time. We always use two silk threads to seal the case halves to prevent this issue developing over time. Some folks use one due to the tight spaces to work around the case half faces. Using too much Hylomar in that around can float the silk out during torque up sequence.
