Canopy Skirt Fit
NavyS3BNFO
I'm in the process of fitting the skirt to the canopy and I have some pretty big gaps near the back where it curves up the fuselage. I've looked at some of the other threads and it looks like some builders have just cut it off and layed up new fiberglass. I'm one of those "avoid fiberglass work at all costs" guys so I'm polling the collective to see if there is anything else I should try before I commit to major surgery. The rest of the skirt fits pretty well.
I found when fitting my skirt that to make that bulge go away I had to raise the tail of each section back where the split is for the slider track. You will need to retrim your top edge which will mean that you have to redrill for your clecos. You can fix this without using fiberglass but the back split is the key from my experience. I can show you what I ended up with but my start was similar to yours.
Thanks. Any additional pictures/detail would be great.
BTW, got to tank from the KC-135 many a time back in the day.
The trick to pull the skirt flush to the fuselage is to cut the slits in the fiberglass skirt and the slits will fold into the fuselage skin. Then you fill the kerfs from the cut with thick microballoons, and put a layup of fiberglass cloth on both sides. Do it slowly and you will get the perfect fit. Don't use heat because it just warp the skirt and create more work for yourself. Some builders don't like cutting into their fiberglass panel but the skirt is NOT structural and this is okay. I don't recommend this method for structural fiberglass.
Skirt with slits cut in
Slits filled and faired with microballoons. Fiberglass covering will come next to make the skirt structural again.
Check in later.
What did you use to cut the slits? I ask b/c I've been using a dremel with a small cutoff wheel to trim the skirt but my sense is the kerf won't be wide enough. Also, did you have to rig something up to hold the skirt flush while the micro dried?
Im heavy into the fiberglass work now and my 4.5" angle grinder with a thin cut off wheel has saved me much time! It slices right through the big stuff. I use a "flapper wheel" to knock down the edges and shape then hand sand the final stuff.
I used this big Dremel Ultra Saw
I used this saw to trim all of my fiberglass panels, cowl, and to rough cut the canopy flashing. This is much faster than the smaller Dremel cut bit. The small Dremel works for many small task but for the big cutting job, the Ultra Saw was my go to tool.
I use a Dremel with diamond cutoff wheels from Amazon to cut and trim fiberglass; it's very precise and doesn't burn or wear out quickly like abrasive wheels. Might need to make two passes if you need wider slits.
Like you, I HATE fiberglass work.
I do not like saying this but I have had better and faster results cutting off what I do not like and making my own with new layup(s).
Me too. I laid up a one-piece skirt from scratch because I knew my frame/plexi fit wasn't perfect and there was no way I was going to make one fit with metal. That whole experience was what taught me I hated fiberglass, but I'd still do it again
I had to make a custom snorkel since Van's was out of stock of the "normal" one and I have a non-standard engine. It still looks like garbage and is three times heavier than it should be, but at least it doesn't have to look good...
Perfect. I have one of those. Thanks.
I kept pushing that edge up until the bulge disappears. The I trimmed back to the canopy line and trimmed and pulled the edges back together where they meet. So many ways to skin the cat. I also lined the inside of the fiberglass with red canvas just to make it look finished on the inside.
Still passing gas for a living, going on 24 years. You were on a drogue I assume. 434 ARW.
Yep, I did the same. Came out ok. Still had to do some glass work at the back joint. Made a small hump over the slide rail and cut it short enough to clear the vertical with the canopy open. Reinforced the underside for the handle. I too dislike glasswork but unfortunately it is a necessary evil. Helpful if you know a guy. ;)
Cut the split until you can pull skirt until it lays as flush as it can. Then start the glassing process.
The vans fiberglass parts leave a lot to be desired. That is putting it nicely. Most of the fiberglass parts from Vans....well, to maintain positive critique, lets just say it is easier to mask off, spray expando-foam, shape, mask, and lay up new. But definitely love PhatRV's posts above. Follow his advice too! Doing fiberglass gets less daunting as time goes on. It really is forgiving, and with care you learn to reduce the post-shaping and rework stuff. More often than not it is easier to shape foam and mask and just lay up new. Then you can lay down one or two more layers of glass mats (more layers compared to the pesky vans ones), and what you have in the end is more temp resistant and dimensionally stable...meaning it will hold its shape in the effects of the hot sun better. Again though I love PhatRV's slicing modification technique!
ANother trick I did on a friends RV8, he had me install his canopy and skirt, and his Vans's skirt, was rediculously out of wack. Huge out of fitment as yours. Don't under estimate the power of gorilla tape and super glue! Seriously. On my friends: I layed down Gorilla Tape on the turtle deck skin. Basically like masked the area off with this. Then I used fast setting super glue....and literally glued the skirt down into place. I then epoxied 2 full fiberglass layers down over those entire aft areas of the skirt. Once cured for 2 days, yes, TWO DAYS!, popping the skirt of was done with a gently nudge of pop sickle sticks. Gorilla tape remove, the fit and gap was puurrrfect! This trick works well to fix fitment issues.
