New sump changed directions on my build. Has sniffle valve also. Sv78950
R ryanevans1018 Member Apr 11, 2024 #1 New sump changed directions on my build. Has sniffle valve also. Sv78950 Attachments IMG_2132.jpeg 1.3 MB · Views: 37 Last edited: Apr 12, 2024
frankd Well Known Member Patron Apr 11, 2024 #2 Is this for the 180 or 200HP? Dash 1 or Dash 3? Thanks
1 1Beege I'm New Here Sponsor Apr 11, 2024 #3 Do you know if the servo pad is in the same location as the stock intake?
R ryanevans1018 Member Apr 11, 2024 #4 1Beege said: Do you know if the servo pad is in the same location as the stock intake? Click to expand... I do not know for sure
hgerhardt Well Known Member Apr 11, 2024 #5 frankd said: Is this for the 180 or 200HP? Dash 1 or Dash 3? Thanks Click to expand... Looks like it's for PV engines, or 180 HP.
Taltruda Well Known Member Friend Apr 12, 2024 #6 hgerhardt said: Looks like it's for PV engines, or 180 HP. View attachment 60490 Click to expand... Yeah it there’s also a “SV78950” for Angle valve engines.. So which ones the is the OP selling? Attachments IMG_2066.jpeg 260.9 KB · Views: 25
R ryanevans1018 Member Apr 12, 2024 #7 frankd said: Is this for the 180 or 200HP? Dash 1 or Dash 3? Thanks Click to expand... I inserted a picture of my invoice. There isn’t a dash. It is for a parallel valve 360
R ryanevans1018 Member Apr 12, 2024 #8 Taltruda said: Yeah it there’s also a “SV78950” for Angle valve engines.. So which ones the is the OP selling? Click to expand... It’s for a parallel valve 360
