Tight tank skins
CaptPausert
I started on my fuel tanks for my RV-9 today. I am really struggling to get the ribs clecoed into the skins. basically the skins appear to have a tighter bend at the nose than the ribs do and it makes it really hard to line it up. I ended up bending a couple of clecos trying to do it. Is there any advice for this? I have them in the cradles but there is a gap on either side of the nose of the skin.
IMG_0751.jpg;)
Tank skins are extremely tight on the 9, if I remember correctly I had to start at the leading edge and work aft on both top and bottom, one hole at a time. Used a couple 3/32 pin punches to pull each rib and skin hole into alignment then clecoed
Tank skins
View attachment 50603;)
Not just the 9. Mine (7) were scarry tight too. That technique works. Once they are on, walk away for 24 hours. Every time after is no problem
I think I remember sitting on the tank skins & using ratchet straps to pull them on at some point. I also tried some draw cleco's to try to hold them in place while I put in the other clecos.
