Cylinder #1 in my Mattituck Lycoming IO-360, 400 hrs since new, built in 2009
Symptoms were low compression (low 60s, came up to 74 after staking the exhaust valve). I get very dirty oil within a few hours. Oil burn is a quart every 3-5 hours.
You can see a scuff on the cylinder wall, Savvy says it looks like it had a stuck wrist pin. There's also the wide dark vertical lines, evenly spaced that I can't identify, but they are not showing in any of the other cylinders.
Video - Cyl #1: https://youtu.be/282Tuh9oENc
Here's a video of cyl #2 for comparison. 3 & 4 look the same as 2. Compression was 78 on all 3.
Video - Cyl #2: https://youtu.be/4nLdtXPAEI8
Savvy recommends just monitoring it, but they always advise not removing the cylinder. I have zero issues buying a new cylinder, if that's what this needs. Engine seems to run just fine other than the dirty oil.
