Let's look closer at the supposed data that shows 8 rudder failures causing accidents, based on the list in the first post:
1. Preliminary report only, cause undetermined yet.
2. Preliminary report only, in-flight break-up, weather involved, cause undetermined yet.
3. Exceeded Vne by > 20% (44 knots).
4. "There were no clear indications that any of the [empennage] components that fractured in overstress did so before ground impact or independently of the bird strike."
5. "damage to the horizontal stabilizers and elevators that was consistent with a downward failure in positive overload. The loads required to fail the horizontal stabilizers and elevators cannot be generated from normal flight or
control movements. Such failures would have required an abrupt pull back on the stick and corresponding movement of the elevator to a trailing-edge-up position, at speeds greater than the airplane's maneuvering speed."
6. Probable cause undetermined because wreckage was not recovered (sunk in 500' of water).
7. "At the time of the inflight breakup, the airplane was traveling 20 knots above the published never exceed speed."
8. Exceeded Vne by 34 knots.
Not one of those indicates to me that the rudder was the initial cause of the failure. Two of those specifically cite rudder failure, both at speeds far in excess of Vne.
Tell me again why the rudder is a problem here?
