Steve Sampson
Why are mags normally wired to 2 lower plugs and 2 upper plugs? Does the reason apply also to electronic ignition?
The wire runs are a little easier if one mag runs all the lower plugs and the other all the upper. If one mag fails you would still have a set of working plugs. It might be the upper or lower, but it should all continue just fine.
Thoughts....or is it obvious except to me?
